I'm sure you are fine, you would have known nearly immediately if something severe had happened due to over boost.
Here's an example where I purposely over boosted a 2.2 L Dodge with the exact scenario you just described. There was no boostcontrol whatsoever (as there was no pressure sorce to the wastegate actuator nipple), and the wastegate was held firmly shut. See how the run ends abruptly? LOL I think your engine is just fine[emoji818]. When really bad things happen from overboost, you generally know immediately.
