Check engine light came on after hitting a bump on the freeway, I got a atp kit installed with the 2860r turbo tial bov & wastegate upgraded. I checked the accesport and told me what the codes were 0035-turbo charger bypass valve A circuit high & 219A- AFR air fuel ratio bank 1) while tuning on my first revision I was reading very low psi, so I got my pre load adjusted to the correct amount, boost shot up to 18 then 19 after my next revision, after the 3rd my psi reading didn’t go up, meaning we have no control of the boost and tuner told me the check all the work on the boost control solenoid, could all this be tied together? Thanks guys
