hi just wondering if some one can help me
SteveS
Osage Beach, MO, USA
  1. NOTE: Make sure that the cylinder head is at ambient air temperature before removing the cylinder head bolts.
  1. Support the cylinder head on a bench with the head gasket side up. Check the cylinder head distortion and the cylinder block distortion.
    Refer to: Cylinder Head Distortion (303-00 Engine System - General Information, General Procedures).
    Refer to: Cylinder Block Distortion (303-00 Engine System - General Information, General Procedures).
Installation
  1. NOTICE: Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges that make leak paths. Use a plastic scraping tool to remove all traces of the head gasket.
    NOTE: If there is no residual gasket material present, metal surface prep can be used to clean and prepare the surfaces.
    NOTE:
    Material : Motorcraft® Metal Surface Prep / ZC-31-A
  1. NOTE: Make sure that new bolts are installed.
    NOTE: Make sure that no fluids are present in the cylinder head bolt threaded bores.
    Torque :
    Stage 1: 5 Nm
    Stage 2: 15 Nm
    Stage 3: 35 Nm
    Stage 4: 90°
    Stage 5: Tighten an additional 90°
O
London, UK
  1. View attachment 34486
Installation
    NOTE:
  1. View attachment 34484
    Torque :
    Stage 1: 5 Nm
    Stage 2: 15 Nm
    Stage 3: 35 Nm
    Stage 4: 90°
thank you do you have to ones for the cams ?????
