Last week's worth of updates. At 34k miles and my passengers side blend door started clicking. Got that and finally the evap purge valve fixed under warranty, only 1 fill up so far and it hasn't sputtered which is awesome. I also pulled the trigger on an AP finally, got a great deal with a couple pre-loaded maps on it used by basically the exact same mods as I have. Ran the Cobb OTS stage 2 for a week, not impressed, there was no perceivable difference between stock tune and stage 2 with my mods. After I got it back from the dealer a couple days ago, my rear brake pads were at 1mm
. Tried to order some through work but they wouldn't get here until next Wednesday. Emailed Fswerks in Anaheim, got an email back at 9:45 pm about their stock, showed up the next morning and Raffi hooked me up with the Stoptech semi-metallic rears. Installed them last night, then loaded up the Stratified 91 flash tune w/o crackles, and oh man that's more like it. Throttle response is top notch, the extra boost (25.7 vs 21.6 PSI) is definitely noticeable. And launch control at 2700 rpm is money.
EDIT: the top boost I've seen is actually ~26.3
