I got the boomba shifter installed along with their shifter base bushings. Just like
flbchbm said it was pretty easy. I did not have to trim the reverse lockout, it worked perfectly as is. Didn't have to chamfer the retaining rod either.
Once I got it all together I was happy with it but had a hell of a time getting into first gear. All other gears were fine but 1st was fighting me big time. I adjusted the shifter, removed my whoosh shift adapter and tried it without and no dice, still fighting me to get into first. I reinstalled the whoosh adapter and re set the shifter at max and came in to check and see if I did something wrong when I saw flbchbm edited his post with more info. I ran out and tried it... flbchbm I owe you a beer! It shifts like butter after doing that procedure! No problems getting into first. Its perfect. I cant thank you enough I never would have found that info.
In more alarming news, I noticed this inside of my intake tube was pretty dirty. I have the raimair filter in the stock air box and I noticed the top of it was covered in dirt. See pic below. I'm pretty alarmed by this. I put the stock paper filter back in for now. I have the velossa tech big mouth so I'm wondering if the pressure it creates is allowing the filter to lift and allow dirty air to pass around it. Maybe the ram air filter doesn't quite fit perfectly allowing it to lift. Anyone else see anything like this?
