1. the tuner usually sends you a Base Map for the first tune after the turbo is already installed.
2. Do the oil prime procedure Accelerator and Clutch hard down 100% then hit the on button. Engine will crank but not start. Do it twice.
3. You can use the same oil, but try to use new oil.
4. The turbo will be breaking in but i doubt it leaves much residue so no worries there.
do I have to keep the start buttom also full press while this procedure and how log time should I remain this presss?
