Jason from Dizzy Tuning created this super useful guide for minimal mods needed.
https://dizzytuning.com/blogs/technical-documents/the-ultimate-guide-to-modding-your-fiesta-st
The complication when asking what are "minimum supporting mods" is there are some mods which aren't technically "required" but if you don't upgrade them, they may fail on you later (such as the bypass valve, symposer delete). And then there are other parts which aren't needed but that are recommended (improved safety/longevity/increased power) and you SHOULD do at the same time while you've got the turbo out (high flow catted downpipe). I tried to go the minimum supporting mods route when i installed my X47 turbo and ended up upgrading more after the fact and ended up wasting some time/money because of it. Better to do it right the first time.
For strictly the bare minimum, EnthusiaST's comment is pretty much it. However for peace of mind and longevity, I'd also recommend:
High-flow catted downpipe (Whoosh catted downpipe)
Aftermarket Blow off Valve or Bypass Valve (GFB DV+, Turbosmart, etc.)
