Minimal supporting mods for Hybrid turbo
I have e30 readily available all over the place. I just bought the MRX turbo today. Any predictions what it could make with an E30 tune?
I made 286whp on 93, when I got my tune I was told 300-310whp was possible on e30. It's just not an option where I live
1) from my reading here and elsewhere the Mountung MR230 tune is good for 225 whp. So you can make things rather interesting with just a tune.
2) In the time I've been here I've come to conclude that the stock engine just isn't capable of holding up with a larger turbo. Yeah, I've seen all the posts about how the cast pistons in these engine can withstand 300 hp but I've also seen posts about 300 hp setups blowing holes in the pistons. Granted I haven't seen any posts about 250 whp setups blowing up pistons but I cannot remember ever reading about someone building a 250 whp bigger turbo engine, it seems everyone wants to do 280-300 hp.
3) At 300 hp you really want to retain the stock downpipe. Not only will it save you money but it's also been designed so that there is a standing vaccum wave at the outlet of the turbo, which means you'll make more power with the stock downpipe.
4) An old (as in ancient) hot rodders trick for a "hidden" power adder is a Larger Radiator. Because an engine running Hot won't make as much power as an engine running at the ideal operating temperature. Many of those Deuce Coupes were running radiators out of a semi tractor. Point is, toss the stock radiator and install a Mountune 3 pass and you'll find full power is 100% available even on a steaming hot August day with temps pushing over 100.
5) Power isn't cheap and never has been. Unfortunately with the complexity of today's engines the cost to replace an engine is very expensive. The days of getting a 100 dollar runner from the junkyard and doing a shade tree rebuild are long gone. So when working on a power plan you need to anticipate how you stage everything. Throw a bit turbo at an engine too quickly just increase the odds for a blown engine. For me the staging goes as follows.
Stage 1 is Cooling, because Cooling is critical for both the health of the engine and consistant power output. So the first things you should do are the radiator and the intercooler. Adding a Water/Methanol system at this point is worth considering. Granted these systems aren't cheap but a good meth system can allow the use of a much more aggressive Tune and it can also act to keep your intake valves clean.
Stage 2 is Breathing. At this point you'll want to address the intake and exhaust systems and take a rational approach. For instance, with only 1.6 litres (98 CUI) you really won't need a 3 inch exhaust until you pass the 400 hp point. So save yourself a bit of weight, and reduce the volume a bit by installing a 2 1/2 inch exhaust. On the intake there is a wide variety of options available so my only recommendation here is to chose a system that has excellent filtration and easy servicing of the filter. I'd also recommend getting a system that doesn't trigger "codes".
Stage 3 is the engine block. Specifically Forged Pistons and premium connecting rods. I also recommend some type of cylinder support system because I just do NOT like an open deck block in an engine running 300 hp or more. If I ever decide to go for 300 hp plus my plan is to get a Mountune MRX Longblock or perhaps the complete engine. I'll also note that after seeing posts about Mountune's engine builder lacking some attention to detail I would plan on checking the torque of every rod cap, main bearing cap, and ever other critical fastener.
Stage 4 is where the Fun starts. You've built a good solid foundation so you can throw just about anything you want at the engine. If you are only going for 300 hp you can get there with just a turbo kit. If going over 300 hp plan on a larger turbo instead of a hybrid and you'll also need supplemental fuel and a Water/Meth kit.
where are you pulling these conclusions from? Most with blown motors I've seen were over 350hp, and while aux fuel is needed over 300whp, meth is definitely not required. There's not much to be gained with an intake, cars have made 350+ with the stock setup. Radiator is poor from the factory, it needs an upgrade. Also, no way you're getting more than 220whp out of a stock turbo
Here you go again spreading misinformation. The engine is perfectly reliable with hybrids and larger turbo’s running up to and around 300 whp. Most the people blowing up their engines are pushing them at upper boost levels and running around 350+whp . We are talking 30+lbs plus boost levels. Which most tuners will not tune for unless you are running aux fuel aka secondary injection system with E30 or more tune.
A larger radiator is important for our cars because the stock radiator is wimpy it will make no difference in power.
What will make a difference in being able to sustain power and boost is a bigger intercooler that will not heatsoak.
Water meth systems are not needed on our cars for cooling unless again your are going for insane numbers and even then its not an absolute requierment.
Your stages are also made up. lol There are stages except for classifying tunes and even that is partially made up hotrod internet BS. lol
Oh and I have friends running 300 to just over 300 whp on stock blocks reliably no problems.
One does not need to spend the money on a Mountune shortblock unless they are planning on hitting 400+ whp on a regular basis.
Plus engines are not expensive you can pick them up all day long in the yards for around $700-900. That is cheap.
$100 an engine is like 25 years ago. lol and would be stupid cheap now.
Oh and the fun starts even with a Hybrid in the 260whp range. I have driven those cars. I would bet you have not as usual you speak from no experience on our cars.
I always thought the fun stared when the road got twisty but maybe that’s just me....
D
Thread Starter #27
I agree with your philosophy. Very well written as well. I believe 250 whp is a good number for this car. A very conservative tune can accomplish this on the hybrid turbo.
haste
One of the reasons I went with the x37 ages ago because it hit my target HP for this engine. Realistically, being a 1.6L engine, how much HP can you possibly push reliably for a long time. Especially with the open deck design. I've had a 250whp tune on my car for over 46K miles now with zero issue and I don't take it easy on it.
Just another reason I am going for a higher final drive ratio on my transmission at the moment is to eek out some more performance from this thing without sacrificing reliability. I hope for it to be a perfect combo for me.
gtx3076
Honestly, you don't need any additional mods besides an accessport and a cutom tune to run an upgraded turbo.
No, you will not be able to push the limits of the car or the turbo. But if you're on a budget and are okay adding parts later and retuning for them, it's really not a terrible mod path.
D
Thread Starter #30
What final drive did you choose? Are you installing LSD at the same time?
D
Thread Starter #31
It’s not about budget. It’s about not over-modifying or should I say unnecessarily modifying. Far too many people think the more mods they have the better, they like to list them off. When many are poorly made/engineered compared to OEM and often provide little to no gains. I want to retain maximum reliability as it’s a commuter car.
haste
I went with 4.35 ratio final drive. I believe it is the only option available at the moment for our transmission. Please let me know if you find something else. :)
And yes, definitely installing a LSD at the same time. I hope to have the transmission built within the next couple weeks and the install should follow shortly afterwards. I'll probably make a thread at some point with a review and some details about the conversion.
gtx3076
#33
Then that makes my statement even truer. The stock turbo seems to be the biggest power restriction on the car. You could swap the turbo and flash a tune and make more power easier than anyone with every intake and exhaust mod on stock turbo.
Personally I think accessport, turbo, intercooler, and maaaybe some intake plumbing. That's been my plan on this car if 2020 shakes out to get better.
#34
I saw intake temps well over 150 degrees with the stock intercooler on a hot day, that's the largest issue with trying to take advantage of even the stock turbo. My only mod at the time was a cobb stage 1 OTS tune
haste
#35
Don't forget radiator.
#36
My wife even notices the upgraded intercooler from the passenger seat.
I didn't ask her opinion I didn't try to get one it came straight out of her mouth. She even said I hope this doesn't sound stupid but the car feels stronger.
#38
I forget it because it's not an issue for me even in triple digit heat.
the stock rad doesn't go over halfway on the temp gauge until it's over 235F. So even if you don't think it's that hot, it's really hot
gtx3076
#39
I monitor with my accessport. Non-issue.
Se7eN
#40
I feel like it's gonna be super short gearing wise. The Ratios are short to begin with. But I understand the reasoning behind it. Get to 100mph much faster without needing more power. It's one of the first thing Honda Owners do regardless of model year. Except maybe 8th gen Si that already came with 4.76 even then they'd bump up to 5.20 in some instances.
