Tips for Fuel Economy from a cheapskate.
1) Turn the Air Conditioning OFF. Believe me, you really don't need it, my Dad didn't get a family car with Air Conditioning until he got the 1969 Olds 98. Grew up riding in cars with the windows open and still prefer open windows. Only run the Air once a week to keep the seals from drying out.
2) This one still has be scratching my head but it seems our engine is most fuel efficient at 190 degrees. Because since installing a Mountune radiator I've gained 3 mpg in city driving. Obviously my tip is get a Mountune radiator.
3) Use the Cruise Control for city driving. Human Beings have a tendency to "flutter" the gas pedal. So if you have a 1/2 mile stretch without any stop lights or stop signs with a 30 mph speed limit set the cruise control at 30 mph.
4) If you are approaching a point where you know very well you will have to stop then coast to that point for the last 3/4 mile. Not on will you save a bit of gas you'll also burn up less brake pad, because it takes a lot less braking to stop from 20 mph than 30 mph.
5) Freeway driving. First, don't use the Cruise Control, use a A Constant Throttle method. Note this will only gain you about 1/2 mpg over using Cruise Control but if you are sqeezing for every tiny bit of gas a 1/2 mpg gain can matter. At about 65 mph on level roads it's possible to see 42-43 mpg on the tattletail. So apply enough throttle to hit that economy mark and hold it there. Yeah, your speed will vary with the grade but we are Fuel Squeezing here so speed doesn't factor in. BTW, here in the rather flat Detroit area speeds will range between 62 to 69 mph. I'll also note that with my 2019 the fuel tattletail is about 2 mpg optimistic.
6) Remember that Friction costs Energy. Huh, what's that all about? It's about how fast we drive around a curve. Going around a curve at 75 mph will scrub off more rubber than going around that same curve at 65 mph. That extra friction at the higher speed WILL impact the fuel economy. It's why when you are driving on a highway with lots of curves you see a drop in your fuel economy even if you are driving like an old lady. If you missed that last gas stop and might not make it to the next stop then SLOW DOWN.
PS; there are times when I say the heck with Economy and toss all of the above out the window and have some FUN. Good news for us is that even when we are having lots of fun these cars are still pretty economical.
