I have mine from earlier this year with the reliability improvements incorporated, and have used it quite a bit, really like it. It does squew the angle of the patttern especially reverse, it feels odd, but I got used to it. Couple of notes to add in case it's helpful:
1. Remove the battery for access, install solid alum bushings for the mounting plate (this is necessary for proper feel and reliable low effort shifts)
2. While you're there, reset the cable so the trans mounted lever is centered perfectly for 4th gear (I didn't do this at first, and I had to reset all the stops afterwards).
3. Setting the stops, requires a certain play/gap when it's in gear between the shifter and the stops. Don't try to make this tight, I had it a little tighter initially then it is now, and had to shift fast and more forcefully than needed, a gentle movement should be able to get it into gear if all is proper.
3. Shift with low or moderate effort/force, it's all that,s necessary once everything is properly set up, and I think it's also important for reliability.
