- Member ID
- #2384
- Messages
- 101
- Likes
- 14
Car had been sitting in the garage for a few days so I decided to drive it. Started it heard the compressor engage, engine revved up a little like normal but HOT air. Pulled out of the neighborhood just thinking the freon needed to circulate more but nope. Drove for a good 20 minutes and it is still blowing out hot air. Every now and then it seems like the air would get slightly colder like 3 degrees or maybe I was just tripping. It has done this before and I took it to Ford and they replaced the climate control module but now I'm getting the same problem. It's always when it is pretty hot outside but the air is still not even slightly cold even when driving. Radiator fan works, ambient temperature sensor is good. It's almost like the cold/hot blend door doesn't move but it isn't broken because when I turn it to all the way hot it blows out even hotter air. 3/36 warranty is almost up idk what to do. 2016 FiST
