A few words, First 10k to make the car reliable? You need to put down the crack pipe.
lol jokes aside man seriously a $500 radiator upgrade makes the car more reliable. not $10k and oh make it faster and I mean a lot faster costs around $2k with tune with a turbo upgrade.
That will make the car more than slightly quicker it will change it by several seconds. You cannot get around the math 300whp in a 2750lb car gives you sportbike acceleration and speeds. First hand experience with this as well.
In fact you can set the whole car up to perform insanely for around 5-6k max . Obviously since you have not done you really do not know as you yourself bailed and went a different direction out of fear.
Thats fine the car stock is freakin blast for $500 for a radiator and $300 -400 for a bigger intercooler and around $500 for an AP and a tune. Its a total blast.
You do not need to go farther unles you just wish too. Yet it will not take 10k
P.S. I am glad you are happy with your Super 7 Interesting but if I was gonna go down the open cockpit road I would get an Ariel Atom over a Super 7 every day of the week.
Oh and most of us bought FiST’s to pull double duty not be a impractical one off.
I mentioned that price because that was the budget. I didn't intend for people to think that
I'm sorry. The cost I quoted was "all in" for what I planned to do. I didn't preface it well.
I went back and dug into the numbers. I actually write stuff down.
Some prices have come down since 2016. But my statement is based on the numbers and what I have learned from six prior car preparations. Three of them full caged, non street driven.
I kept the streetable intentions front and center when I planned my FiST.
I kept things very conservative. Stock turbo and exhaust system. I actually have a lot of the parts. I upgraded the radiator after I installed the hood vents on a service replacement hood panel. My plan covered eight specific areas. Noticably absent from the list is any splitter or undertray. No chassis braces because 15 inch wheels and a Pierce 6point brace is very unfriendly on the street. No harness bar or cage. No coil overs or double adjustable dampers. No aftermarket anti-sway bar. I did remove the rear seat and belts.
Some rebates were applied to the costs.
Power upgrades- $ 2,260 sbtl
Cobb stage 2 $ 1,800
Catted downpipe $ 500
Cooling upgrades- $ 1,170 sbtl
Radiator $ 500
Oil cooler kit $245
Hood vents $ 275
Silicone hose kit $ 160
Transaxle upgrades- $ 2,475 sbtl
Quaife differential $1500
Misc diff' install bits $210
Short throw shifter $225
Spec, stage 3 clutch kit $ 540
Issue mitigation-$ 265 sbtl
Oil catch can $200
Spare cooling fan relay $20
2, fire extinguishers $45
Electrical-$230 sbtl
Water temp and oil pressure gauges $60
Battery relocation kit $110
Shut off switch $ 60
Suspension upgrades- $1,143
Koni Sport damper and spring kit $950
Powergrid adjustable end links $165
Energy Suspension poly ASB frame bushings $28
Brake upgrades- $ 703 sbtl
Performance pads and rotors (STD size) $ 335
Stainless steel brake hose kit $ 118
Front brake cooling duct kit $250
Wheels and tires- $2,900 sbtl
8, 200 treadwear rated tires one set shaved. $ 1,100
8, lightweight wheels 15/16 inch diameters $ 1,800
Component cost $ 11,127
Labor $ slave
