How about when it’s 110 outside?
I generally try not to drive very hard when it gets that hot out, because I’m aware of the reputation of the cooling system. That said, it rarely gets above 100 F around me, but there are strategies you can use with the stock radiator that will help keep temps down:
Throttle management: horsepower, or the work your engine performs, is a function of engine load. If there is not something preventing the engine from hitting the RPM commanded by the throttle it will only generate as much horsepower as necessary to maintain the commanded rpm. This is why it’s nearly impossible to hit a significant amount of boost with the car in neutral, the engine can hit the commanded rpm without using the turbo. So try to do the bulk of your acceleration gently or, terrain permitting, on downhill sections. This will limit the amount of heat your engine generates.
use a lower gear than you normally would, this keeps rpms up. More RPMs mean more coolant circulation, and more coolant moving through your radiator overall increasing the cooling efficiency even in a somewhat flawed system like the FiST’s.
Engine braking and coasting. Again this has to do with engine rpm and coolant circulation. You can also mitigate your time you spend completely stopped if you coast just right coming up to a stop light.
These are all relatively simple “driver mod” strategies that cost nothing to implement but can have a surprisingly strong effect on your coolant temps especially if you are having issues.
