just ordered my s280 and all the supporting mods, im also getting tuned by dizzy as ive had 2 previous tunes and was more than satisfied and heard hes pretty good with the s280, im hoping it wont be too much of a pain for install.
would you guys who have replaced your turbo for a s280 say it was simple to install?
should i drop the subframe or can i remove it from the top?
should i remove the manifold with the turbo or just the turbo?
any pointers or tips that you guys did or advice on problems you ran into that could be avoided now that you know after install?
all advice and tips are greatly appreciated.
have a great one!
have a great one!
Get the heat shields and hard coolant lines out of the way first and soak your O2 sensors with penetrating oil well in advance if you are doing the down pipe.
I removed the turbo with the exhaust manifold from the top, but I was also replacing the exhaust manifold with the Whoosh manifold. It might be easier that way anyway.
Make 100% sure the turbo isn't touching the engine block. I pre installed my turbo to the manifold, and I had to grind quite a bit to get 1/32" clearance hand fit, which was 1/64" after torquing the manifold to the block. It can't touch or you may end up with an exhaust manifold leak, or stressing the turbo.
Before you torque the manifold make sure your upper oil line will start or at least aligned, you can pinch it and bugger up the seal if you aren't careful.
Take your time and make sure the hoses are properly positioned before you start tightening the clamps and make sure the clamps are installed so you can tighten them if you have a leak. You don't want to have to uninstall the turbo just because you can't tightent a leaking clamp.
Make sure the crossover pipe lines up to the intake hose before you clamp up.
Enjoy your new S280 turbo....it's an amazing improvement IMO and Jason @ Dizzy is a great tuner!
