Thread Starter
#201
Well its was bound to happen atleast once in my life whether it be with this car or another.
Went to Heartland June 18th for a track day. Car was fantastic, impressing people, ran lovely. Fast forward to the last lap of the last session on the front stretch I shifted from 2nd to 1st instead of 3rd. Saved the trans by immediately pushing in the clutch because it shifts perfectly fine but the engine isn't happy.
I'm thinking it either bent a valve or jumped timing. It still runs, nothing leaking but at low RPM cruising sounds like it has a cam on it and just isn't running happy at all.
I get all my 25PSI of boost but the car literally has NO power at all. I was able to limp it 3 hours home and now I have it in my friends shop at his house so I'll be tearing it open and finding out the issue.
First time this has happened to me so I'm counting my blessings. Atleast I didn't run into the wall or crash the car in some sort. Engine parts can be replaced, I cannot. I also can get a new OEM long block for a good price if it moves towards that situation.
2 of the 4 cylinders showed 90psi when I did the compression test. Others showed 150psi
