I just read your other post:
May 24, 2020
"Since this thread is older than mine I'm going to bump. Getting the same code as well. So far I've changed: crankcase vent valve, valve cover which includes pcv valve, checked all vacuum lines and made sure both catch cans were closed, cleaned throttle body, reinspected and reinstalled intake gasket for both manifold and aux fuel, bought a brand new manifold as a known good, rechecked throttle body gasket and realigned, recalibrated throttle body, replace MAF sensor, checked for leaks in all charge pipes, tightened all bungs including tmap sensor, installed new o ring in map tap for better seal, bought new oil dipstick, checked for exhaust leaks, resealed exhaust anyways. I cannot find where this p2282 is.... The only other options I have are 1 tune isn't measuring air properly or 2 an intake valve is messed up. I would otherwise ignore it but it's causing an excessively high number of misfires at high rpm. With a tech in the car with a diagnostic tool in mode 6 we saw 500 misfires on both cyl 2 and 3 in 10 seconds at 4000 rpm held."
I don't know if I missed other posts relating to your situation, so pardon me if I ask questions already asked... Did you check that 2015 evap harness? Since you have a Mountune engine, you can't tune it back to stock tuning for testing, can you? What is your plug gap?
I'm sure you've already read:
https://www.obd-codes.com/p2282
Causes for this code may include:
Large vacuum leak on or near the intake manifold
Defective MAP or MAF sensor
Bad intake manifold gasket
PCM or programming error
And read this:
http://www.stratifiedauto.com/blog/misfires-and-the-ecoboost-when-should-you-worry/
and this:
https://www.motor.com/magazine-summary/diagnosing-ford-misfires
and finally:
if you have a misfire that you cannot fix by replacing ignition coils and spark plugs, this is a common problem on some Fords. They will develop a misfire on 1 or more cylinders and you may not even get a CEL. The misfire is sometimes caused by a burnt ignition driver in the ECU.
May 24, 2020
And read this:
and this:
and finally:
