I have a hard time agreeing with some of your findings, mainly the claim of decreased clamping force. To help clear things up and further my understanding, can you provide more background information on how you came to the conclusion that these calipers have a "21% decrease in clamping force when compared to the OEM front calipers"? Some math calculations or references would be very helpful.
The idea that these calipers provide less clamping force just didn't make sense to me so I had to do more research. I have provided some proof in the form of mathematical calculations below.
With regard to hydraulics, the equation for force is;
Force (lbs) = Area (sq.in.) x Pressure (psi)
*In the following calculations, I will use 500 psi for the applied braking pressure to simplify things.
To find area of a piston, I will use the equation;
Pi (3.14) x r2 (radius squared)
OEM Caliper
Single piston caliper
Piston diameter: 54mm or 2.13"
Piston area: 3.14 (Pi) x 1.13" (radius squared) = 3.56 sq. inches
Force per caliper: 3.56 (sq. inches) x 500 (psi) = 1,780 psi
Total force applied (both front calipers) =
3,561 psi
V-MAXX Caliper
4 piston, differential bore caliper
Large piston: 35.5mm or 1.38"
Small piston: 32mm or 1.26"
Piston area (large piston): 3.14 (Pi) x .48" (radius squared) = 1.50 sq. inches
Piston area (small piston): 3.14 (Pi) x .40" (radius squared) = 1.26 sq. inches
Total piston area: 1.50 x 2 (large pistons) + 1.26 x 2 (small pistons) = 5.52 sq. inches
Force per caliper: 5.52 (sq. inches) x 500 (psi) = 2,760 psi
5,520 psi
Percentage change:
5,520 - 3,561 = 1,959
1,959 / 5,520 = .35 x 100 = 35% increase
Conclusion
The V-MAXX calipers provide a
35% increase in clamping force due to the increased surface area provided by the 4 pistons versus the OEM single piston.
Feel free to check my math. I want to present the most correct information regardless of how it reflects upon myself or the V-MAXX 290 BBK. The big difference here is the piston surface area that the hydraulic pressure is being applied to. The OEM caliper has one large piston, whereas the V-MAXX caliper utilizes four pistons that have a greater surface area altogether.
References
Piston Area Calculator (used to double check my math, plus a useful tool)
https://brakepower.com/help_abc_27_PAC_t.htm
Basic Hydraulic Formulas
https://flodraulic.com/formulae/basic-hydraulic-formulas
