Doing some research on bearings and such for the car and the LSD install it's become apparent that the differential bearings are hard to come by currently - the race (cup) especially.
From what I've gathered, Tasca lists the Differential Bearing
HERE, which has a definitive R38Z-24 as double checked by this reddit post by /u/sluggyjunx
HERE. So, trying to cross reference this R38Z-24 is not easy but I believe this Russian (?) site
HERE lists the proper cup size when utilizing 'standard' part numbers as Timken LM29749/LM29711. This is backed up by a random bearing website which lists the same cup size as an alternative
HERE. The LM29711 is the cup we need!
NTN and TImken are the only 'real' suppliers of theses otherwise you get in to Chinesium territory - I wouldn't even order off Amazon as I was shipped some Chinesium instead of the SKF ordered... frustrating.
So, new bearings will be a week (that race is hard to come by - out of the USA) and so I'll get everything sorted and prepped that I can in order to be ready for it. Purchased locally!!
Car looks pretty sad with the entire front end off and gearbox out!!
I figure I've come this far, might as well add the $200 clutch to the works so I'll have a brand new one in. Lastly, I've pulled the turbo in order to get it spec'd out for a repair kit so 'we' in North America can FINALLY have a repair kit for the X-47 which can be installed locally and avoid stupid shipping charges to the UK. This was in the works a while ago but the local guys didn't understand my request the first time so... here we are the second time.
Besides stripping the fuckin' oil drain hose torx it was easy enough to pull the turbo for the 4th time! I found a replacement BOLT for that stupid T-30 screw. Not dealing with that again.
