Sick car! I dig it. Any awesome footage to share or parts and build breakdown?
Not too sure about "awesome" footage, but I have some video from a few events. I'll have to figure out how to get it into the Youtube so I can share it.
I'm still trying to determine fact from fiction when it comes to some of the internal parts for the build... when I bought the car there were many people in the Detroit area who said they were associated with Ice Nine or knew one of the previous owners, so I have many stories about wild boost pressures, turbo upgrades, Quaife Diff, etc.. but so far most have proven to not be true.
The chassis was shipped to Team O'Neill for the cage install and suspension bits.
Completely gutted (although still have
A/C compressor and condensor? - on the list to come out)
What appears to be a stock driveline, stock motor/trans and stock tune.. (Currently seeing 19psi with 21 psi overboost, but older photos of the car show a COBB tuner and many stories of ~30psi?)
Banks Turbo back 3"
exhaust
Unknown brand FMIC with GReddy? BOV
17" Braid wheels powder coated by Team Illuminata with Blizzaks and 15" Tire Rack Special wheels for the MRF ZDM3's
Hydro E-brake
Stock cluster and gauges (For now..)
All 4 door windows switched to Lexan (Need to add window sliders)
All 4 doors gutted with carbon close out panels
Carbon hood with 4-post mount
Carbon grill insert
Carbon naca ducts replacing the A-pillar quarter glass
Carbon rear spoiler
Roof scoop with air vents to cabin
Carbon sunroof replacement panel
Driven Motorsports steering wheel
Sparco Ergo Drivers seat
OMP passenger
G-force 5-point harnesses
Stop Tech Stainless brake lines
EBC Yellow Stuff Pads
Autozone OEM replacement rotors
Pentosin DOT4 LV
Brake fluid
Heavy duty aluminum skidplate
Vibrant Ultra Quiet Muffler
Awesome, thanks. I run a similar setup with a 3/4" lift and
Bilstein B6 F/R with OEM springs. I run for similar wheels for rallyx and I know the offset is not nearly low enough for the car to look good with the flares, hence my question about the spacers. Those spacers look sketchyyy lol
10/10 on sketchiness lol do not recommend.
When they built the car they shelled out for some nice braid wheels. I always wondered why they didn’t just get the right offset to start.
And if the 2" lift proves too much, I'll dial back to something closer to what you're running.
Those might be the R2 Bilstein/M-Sport 'budget' option, fronts (as compared to the multiple adjustable, remote reservoir, R2 Reigers which cost 4x-5x as much).
But you mentioned that the fronts were single adjustable (for rebound I'm guessing?), which those R2s were most definitely NOT, as they had NO adjustability for rebound/compression whatsoever, so
Hey M-Sport, I just went back and edited that, they are non-adjustable, you're right.
I thought they had a knob on top for rebound or compression, but they do not.
