- Member ID
- #8129
- Messages
- 51
- Likes
- 5
Did I blow the brand new slave cylinder!!!!!
Just finished a lsd,flywheel and clutch job.
Car wouldn’t go into gear when running. If i turn car off it would go into gear without using clutch.
I bleed clutch several times and had a firm pedal. At one point I was able to slip into gear but shifting into gear didn’t seem right. After a Few try’s I lost the clutch pedal pressure. I was able to slip it into gear while off to get back home. Now I can’t build pressure for the clutch. Did I blow the slave cylinder??
Any help would be greatly appreciated
