Thread Starter
#101
Thread Starter
#101
Looking at the pictures, it looks as if the crash brace is rubbing but you said you spaced it out. Do this - and should be fairly easy to do. Remove the brace completely and check the nuts on the exhaust clamp. It looks like there should be a little more threads showing. Lastly, replace the OEM gasket bw the downpipe and the catback with the 2JR 2 bolt gasket.
What I have noticed is the exhaust gets quieter with the larger downpipe vs the OEM downpipe. MeFisto, are you running a stock DP? With the race DP and 2JR catback, its actually pretty quiet. I wonder if the stock DP is causing some of the resonance.
There is a vibrant resonator I really like and holds up well to abuse. I made the exhaust so the resonator can be swapped out easily. Let me build one ASAP and see how it does - and we can make that a simple bolt on option.
http://vibrantperformance.com/catalog/product_info.php?cPath=1022_1033_1055&products_id=47
