Blow Off Valves
North Carolina
New to boost, opening to learning everything I can. Whenever I buy a BOV, is there anything else I need to do to help prevent any long term damage to the car?
Rocketst
Chesapeake, VA, USA
Bovs don't inherently cause damage to the car but they are important because they relieve unneeded or unused pressure the turbo makes by allowing an exit other than the combustion Chambers. Stick with a good quality turbosmart or tial and you shouldn't have an issue. Also depending on the amount of boost you run you may need an external bov. For me I'm running 34 so that's why I opted for a tial bov on the cold side pipe.
Vacuum operated/Mechanical BOVs will always be more dependable than Electronic BPVs or BOVs. I have a Tial with my Gen2 And it has worked flawless even through the Depth of winter.
RubenZZZ
Montclair CA
Go on YouTube and listen to the different brands of BOVs to find the one you like.
I currently run a Turbosmart piece, but will likely swap to a HKS SSQ unit once I find a cheap used one.
D
North Carolina
I’ve always loved the sound of a HKS, but I’m leaning more towards Turbosmart at the moment.
flbchbm
Sterling, VA, USA
Keep away from others that consider it annoying/obnoxious and just an ego inflator. Never know when a neighbor might get tired of it. lol
Twin Falls, ID, USA
BOVs on the FiST is a cool topic because of how many options there are. Normally I'm a fan of crowd-sourcing but I would also highly recommend personal research. Each BOV type has different pros/cons sounds/performance. I'd dig in to see which aligns with your long term build goals.
D
North Carolina
I went with the Turbosmart Kompact BOV from Mountune!
D
North Carolina
Well, with the corona virus going on, I unfortunately had to cancel my order for the Turbosmart BOV. Still waiting on a refund from Mountune, and it’s been a week. So this brings me to one other question, is the symposer delete a must for a BOV, or does the BOV take that spot?
Rocketst
Chesapeake, VA, USA
Which one did you order? They do make a symposer replacement bov but they also make the one that fits on the turbo.
RubenZZZ
Montclair CA
If you run a symposer delete style BOV, you’ll need to buy a recirculating valve delete plate (or just unplug the recirculating valve connector) and get a recirculating Valve mimic plug/ have it tuned-out by a tuner (assuming your have AP3).
The BOVs that bolt onto the turbo like the factory electric recirculating valve doesn’t need all the other considerations.
haste
Eastern
[SCAMMER ALERT] a tial bov on the hot side pipe. I noticed it's open during idle, leaving a big hole. Does this not allow the engine to ingest dirt/dust during idle conditions?
No it will not. As soon as the Throttle is actuate/Pressed the BOV closes and then opens when you let off the accelerator. Plus when its at idle it is moving enough air to keep from anything entering the BOV port. I also thought the same thing as it was explained to me by a BOV Vendor for my Typhoon.
haste
Eastern
Still doesn't explain it to me. It is on the unfiltered side of the intake. What about vacuum levels during engine braking? They are higher than at idle. It seems the engine would "suck" in some dirt from the unfiltered side of the intake. Why does tial sell different springs for their BOV, if that is the case?
Mine is on the Hotside pipe as Per ATP recommendations. I could get a video of my Typhoon it runs a JGS BOV on the hotside pipe also. Give the engine a couple revs and show you it if you want.
haste
Eastern
Well, crap. I don't know why I said HOT side. I meant cold side. Either way, still after unfiltered air...
