Here’s my sporadic update:
As I believe I’ve mentioned previously, the plan was to put miles on the FiST with the conservative 93 tune and turn it up later on. Well, back in January, the FiST made its way back up to Panda. It has received a new (22k miles) transmission, new OEM brakes, stainless steel brake lines, new A/C components, and a new vacuum pump as oil was leaking. Currently waiting on weather to clear up to make sure all is good and then it will move on to a compression test and into getting turned up on the dyno.
Still quite a bit of road ahead but this is all for the sake of longevity and performance.
