Fiesta Rear Power Outlet Wire Location
Turkey
Hello, i m from Turkey and i need some help about rear power outlet. My car hasn't any power outlet on rear. I want to add it but i don't want to get extra cable from front power outlet. In my fuse box i have rear power outlet slot and i have a fuse in there. But i don't know where it's wire coming from, can you help to me? I need picture about wire and connectors.
U.S. Navy Veteran
SFV, So.Cal.
The furthest one to the rear is in the end of the center console.
I put in a high power wire from the battery to the cargo space for my Sub-Amp connection.
E
Turkey
I want to use original fuse and wire from fuse box. There is a line for rear outlet and in my opinion there must be a connector or slot for wiring.
U.S. Navy Veteran
SFV, So.Cal.
What fuse number and location do you speak of.
I have a '14 ST and the wiring are the same as your '15.
However, mine is USDM and yours may be different.
E
Turkey
Here is my car fusebox. 29 and 30 fuse is front and rear power outlet. Adsız.png
U.S. Navy Veteran
SFV, So.Cal.
Yes, different markets.
Mine is fusees # 32 & 33
The main power point is in the front of the center console.
The aux-power point is in the rear of the center console.
Try using a test light in in each of the power points and remove the fuses one at a time to see what the fuses control.
E
Turkey
If your car has original rear power outlet, can you send to me picture about your plug connection wire and it's first-final point? May be i can make it easier. I need wire location and connection information, if you can i will be very happy
U.S. Navy Veteran
SFV, So.Cal.
Because of different markets, your connector or wire colors may not be the same.
