My sister-in-law's husband is a bike loveing fanatic his bike frame is several thousand dollars. You can pick it up with one finger. Do you think it's stronger than a heavy steel frame bike yeah it is.
the intake is available now in wrinkle black and gloss red to match our crossover pipes
this intake replaces the airbox ONLY but is modular. It can be installed on any 2014-2019 with no evap harness changes
you can add the silicone induction hose and crossover to make a complete intake system for under $300 shipped
this may help
The RAMAIR intake is discontinued
We have 1 kit left in stock then that's all folks
Our intake is similar that it points the filter down. The mounting is different as is the filter arrangements since the RAMAIR has a permanently mounted filter.
Pipe size is identical
RAMAIR has a heat shield, our does not.
...or having to pay 3 times plus the co$t of Dekagrams for certain ones (which are also one inch narrower than, and 3+ pounds heavier than the Konigs, as well as NOT being Flow Formed) which are ridiculously GOUGED by the North American distributors for Speedline.
