TTR Engine and trans mount install
Boston
Hello FiST Forum. Looking for someone with access to Fords manuals for the specific torque specs on a 16 fist pass side engine mount and trans mount please. TTR only provides the torque for their bolts not Fords. I have the rmm already in just want to complete the set today
jeff
Evans
Here's the entire manual:
https://www.dropbox.com/s/s7wts7x85s2yu9e/2014 Fiesta.zip?dl=0
PASSENGERS SIDE
3 closest to engine are 80Nm
3 others are 48Nm
DRIVERS SIDE
18mm large bolts are 125nm
15mm are 89nm
Check out this thread if you don't want to deal with finding it in the manual:
http://www.fiestastforum.com/forum/threads/14411-Powerflex-Motor-Mount-Inserts?highlight=inserts
Good luck.
S
Boston
Appreciate it greatly thanks for the response
Cherry Hill, NJ
PASSENGERS SIDE
3 others are 48Nm
DRIVERS SIDE
15mm are 89nm
Good luck.
Do you happen to know the torque spec of the bolt going into the passenger mount? I bought an ARP bolt to replace it and will need to torque that one down as well.
jeff
Evans
Passenger side engine mount:
Middle Bolt 50 ft/lbs
Mount to Motor 59 ft/lbs
Mount to Body 35 ft/lbs
Helpful info/install pics here:
https://www.fiestastforum.com/threads/arp-motor-mount-bolt-install-from-whoosh.17305/
Cherry Hill, NJ
