I built the first 1zz turbo Matrix in the world, the gear ratios and being a 5 speed sucked and a bunch of forum members were drying for an LSD as it did not even have an E-diff. They best deal I could find, ten units minimal, better gears and diff, labor not included but the gears were far stronger than stock and a pick of several final drive ratios, 5 speed, $5k, 6 speed conversion, over $6500. I offered to do a GB and installs to help others, not one taker as you can imagine. I ended up having Phantom Grip make me there low cost solution as it was the only thing I could get, shipped the diff, got it back in 10 days, total was around $400 and it worked very well. I installed a few, made easier in that there was dialing in the back lash but I had to make several tools to take the transaxle apart, it was far trickier than working on the FiST unit.
If FWD cars were made with a diff you could unbolt without pulling out the whole transaxle this would be a far simpler, faster and lower cost mod but we have what we have and nothing much can be done except DIY or pay a significant amount for the install and find somebody good at it.
Here is an option for you SS and not the best, customers send in their transaxle or they buy one at a wrecking yard from a car not seriously damaged in that area, send to you, do the swap, send it back, if the trans is not good it is not your fault, just the diff.....still not a great way to do things unfortunately.
I highly appreciate your offer to help others out and save money while doing so but just not a good way to go overall, very unfortunately![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
