Turbo Technics S280
wetwea33
langhorne
Yeah I would of bought cat'd but i literally ran out of money lol. I will be cat'd when i recover.
Meh I'm in pa catless and I've never had an issues with emissions. You just have to take it to a place that's busy and use a defouler.
SANTEE
I'm from Montgomery county. All my cars were straight piped except my boosted integra. In California, it's a different ball game. I'm definitely not touching anything for a while
wetwea33
langhorne
Ahh commy Cali will do it.
wetwea33
langhorne
Did you drive it on the base map for a few hundred miles then datalog at wot?
No just give it 30-50 miles but honestly I didn't even do that on this turbo or my hybrid. Priming it with fresh oil before starting it and letting it idle for 20-30 mins after that are important.
MagnetiseST
Dania Beach
Pretty sure I just idled for like 5-10 min while i buttoned it up. Not a bad suggestion though.
SANTEE
Wooohooo I'm definitely a noob. There was a yellow mark on the feed line bolt. Is that to line the bolt up a certain way? I knew I tightened it. It's on top so it cant be the drain line. I heard it gurgle and then let go. It drained a bunch after that. It was idling for at least 8-10min
wetwea33
langhorne
Did you make sure the crush washer was on?
SANTEE
Here is my 6th revision. tuner says were finishing up but im going to ask him to push it further and utilize the aux up top to get the most out of 93 octane. aiming for possibly 27-28 psi but we will see.
https://datazap.me/u/westley-roy/s280-revision-6?log=0&data=4-5-8
Looking good! I thought I made sure but I'm going to remove it, clean up the oil and make sure the hole is clean of any debris. I'm hoping it was a dumb miatake
JDG
Conshohocken, PA
wetwea33
langhorne
This is WITH aux fuel? Why is it leaning up up top?
We haven't adjusted my aux fuel tables since I was on my hybrid so idk how it's functioning right now.
JDG
Conshohocken, PA
I don’t understand. Why wouldn’t you adjust the aux fuel tables? Who is your tuner again?
wetwea33
langhorne
The aux fuel uses a separate controller and uses map voltage to adjust for fueling. So up to this point it hasent mattered but we're gonna have to adjust it now.
SANTEE
What kind of boost were ya'll making on the base map because it kind of sounds like I have a boost leak
wetwea33
langhorne
It's ussually just wastegate pressure. The spool of this turbo sounds very different then a stock or hybrid turbo.
ron@whoosh
Vendor
Las Vegas
base map with supplied WGA is going to be 5-7psi
as long as the base map is 0 WGDC % which most are
