Old School Hi Tech brake bleeding circa 1960. BTW, I think this may have originated in NASCAR, those southern boys were quite adept at being efficient while using what they had on hand.
First, 3 things you have to be careful about observing, so if you have 3 people working together a full brake system can be bled quite quickly. Number one item that has to be watched closed is the
brake fluid reservoir, don't let it empty or you'll have to do it all over again.
Items needed. A bit of rubber or nylon tubing that will tightly fit a
bleeder valve, a small can of heavy wheel bearing grease, and a 1 pint or 1 quart Mason Jar. Note you can use a pop bottle but they are very easy to knock over and create a mess. You'll also want to put some good deep scratches on the Mason Jar so Momma doesn't try to use it for canning.
Now for the method.
1) Start at the farthest caliper from the
master cylinder.
2) Remove the
bleeder valve from the caliber and apply a thick coat of grease to act as an Air Seal. Screw the
bleeder valve in until it seats and then back it out 2 turns.
3) Put about 2 inches of
brake fluid into the Mason Jar.
4) Take that bit of hose and put a nut that fits snuggly over you hose over one end to act as a weight. Put the weighted end into that Mason Jar making sure that the end is submerged. Take the opposite end of that hose and snap it over the
bleeder valve. Now you have a gas tight seal between the bit of
brake fluid and the caliper.
5) Get into the drivers seat and start pumping the brake pedal to pump
brake fluid into that mason jar. If you have someone watching you can just keep pumping until the reservoir needs a refil. One reservoir of fluid should be enough to totally fill the system from
master cylinder to the brake you are working on.
6) Close the
bleeder valve on the completed brake and remove the hose and move to the next brake and start and item 2 and repeat.
Notes:
If you use clear vinyl tubing and have third person to watch the fluid going into the Mason Jar you can call the job done as soon as you stop seeing bubbles in the fluid stream.
To minimize air migrating into the brake system I would suggest having a box of sharpened wood pencils handy. Cut them to a stub with wire cutters, or rose clippers as needed and jam the point into any open fitting as needed to plug that opening. Note, if anyone hits the brake pedal with these plugs in place they will ALL blow out and you'll have a heck of a mess to clean up and a brake system FULL of AIR. So complete each brake as an individual project and make sure that everyone near the car understands they MUST NOT TOUCH THE BRAKE PEDAL. I would also suggest locking the doors just to provide another layer of security.
