What are the codes set for the ABS module? That is a completely different system from the PCM/ECM codes. You also must have a scantool program that can read ABS and SRS codes.
So I took Forscan out again today and this is what it reported
Nothing from the ABS module which I found interesting as the ABS module doesn't even show up. Maybe the car is not connecting with the ABS module at all and that's what is causing this whole mess?
Below are the codes and what they say:
Code: P1934 - Vehicle Speed Signal
Status:
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Code: U0121 - Lost Communication With Anti-Lock
Brake System (ABS) Control Module A
Status:
- Test not complete
Status:
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
Code: U0028 - Vehicle Communication Bus A
Additional Fault Symptom:
- Bus Signal/Message Failures
Status:
- DTC Present at Time of Request
Module: Restraint Control Module
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
- Previously Set DTC - Not Present at Time of Request
Status:
Module:
Power Steering Control Module
- Missing Message
Status:
Module: Instrument Panel Control Module
- Invalid Serial Data Received
Status:
Code: U0010 - Medium Speed CAN Communication Bus
Status:
Module: Remote Function Actuator
Status:
Code: U2005 - Vehicle Speed
Status:
Module:
Body Control Module
Freeze Frame :
-REALTIME: 193836793 s - Total time ECU has been active
-DIST_TOT_VEH: 69001.0 km - Total Vehicle Distance
-MOD_SUP_V: 13.50 V - Module Supply Voltage
-PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
-PWR_MODE_KEY: Running - Power Mode Key State
