I mean it's less then 100$ more then a v3 and I'm pretty sure I had to remove my uppershield for my v2 anyhow that thing was a squeeze and a half, who cares tho.
I mean in the long scheme of things it's nothing when you look at how much it takes to go fbo and hybrid. It's much better to spend up front and be happy then spend a small amount less and not be happy with the results. If you thing 100$ is something when it comes to cars then I don't think modifying is for you lol.
I had to remove the factory mounting for the "factory fit" FMIC, this unbolts and is reversible. I also had to cut some of the lower wind deflector off so that it would fit under the intercooler, this piece is separate from the bumper and can be replaced if you need to replace it. Otherwise it went right on.
If you're going to go big turbo and do anything besides the ocassional pull / race then you'll need something larger than factory fit (unless its a V3/CPE)
Nope, nothing crazy. I've gone down the motor build path before and had a bad experience. Baby big turbos and stock motor is all I will do for this car.
I have a Mishimoto, but I don't see any temperature variance with the BA on it. Its not any higher than it was before. So I can't imagine it would be different with stock.
Hybrids? You'll need a CPE or equivalent. Hybrids make more heat than true big turbos.
This intercooler / whoosh v1 / etc wont support something like a VT330R / S280 / equivalent. I know this from first hand experience.
By support I mean consecutive pulls. It would be fine for daily driving and little abuse. But once you start getting hot, it won’t be able to cool down.
