I'm not sure why I haven't noticed this before, but why is the bottom half of the front grill solid? The honeycomb is just a facade for the bottom half. What would be the drawbacks (if any) to drilling it out to increase airflow to the radiator?
Ford did that on purpose. it literally cuts down on turbulence airflow wise as that whole blocked off area is covering the crashbar. People open it up thinking it hellps airflow to the radiator. It can actually can cause more turbulence as the air hits the crashbar and suddenly shoots upward hitting the incoming air that has a straight path into your condenser and radiator. Which will disrupt flow,.. now if the crash bar is removed? It would be a different story and one could also cut channels for airlfow in the crashbar.
take a look at the Pro Allow crash bar for an example of that.
Ford did that on purpose. it literally cuts down on turbulence airflow wise as that whole blocked off area is covering the crashbar. People open it up thinking it hellps airflow to the radiator. It can actually can cause more turbulence as the air hits the crashbar and suddenly shots upward hitting the incoming air that has a straight path into your condenser and radiator. Which will disrupt flow now if removed the crash bar that is , it would be a different story or even cut channels for airlfow in the crashbar.
Interesting. The Pro Allow crash bar looks great but it doesn't seem to be available separately -- dang.
Any thoughts about drilling out the holes and backing them with a louver to direct the air under the crash bar? Of course, Ford could have done that but maybe the extra cost wasn't worth it to them (?)
After seeing that the grill is blocked, I can see why. The lower grill only provides air to the intercooler, and the upper grill only provides air to the top of the radiator. Shouldn't the lower part of the radiator get some love?
I have a Mountune radiator; it's fine during normal driving, but I managed to hit 228 degrees at the track running E30 (ambient temperature was between 95 and 100).
There are ways to combat heat and better airflow in and out of the block is first. Cerakoting external and internal engine parts is next. Reducing heat soak should be the ultimate goal which is a multi pronged approach
Before I sold my last car, I cleaned the engine bay with a gentle stream of water, diluted Simple Green, a lot of brushing with a soft brush, and then dried it with my leaf blower. Worked great!
