yep, we know.
A couple of the guys in the UK like collins, laird and a couple of guys have done it. I bet Adam from tune+ and Bryan from JST can do it also.
Either way, even if you change the injectors, they are not going to do much, the limiting factor is the HPFP not giving enough pressure at high RPM's
Direct injecton injectors are not the same as port injection injectors, that if you are running out of fuel you just put bigger cc injectors in them.
