My idea was on the stock DP to just cut out the restrictive areas and weld in sections to free up the flow. It was not something I have ever done, it was it was based on an idea to help those that wanted to stay as stock looking as possible for whatever reason yet help the DP flow better.
I considered doing it just to test it out to see what happened but instead just stuck with a big DP.
I did not consider the metal particles getting stuck in it and starting to clog it up, make sense, one would have to use a different method to cut it open.
I have used quite a few aftermarket high flow cats but none for longer than 5k miles or so thus did not know they usually start to fail at 10-15k miles.
Russ,
If header wrap will cause corrosion on lessor grade materials it might be better to use a metal stand off heat shield to protect things near it instead of wrapping it, which I always done except once, on this car.
I use 305 or 409 SS when I build such parts, depends on what I can find, I use the best when available.
Would you consider them good enough to wrap if one wanted to do so?
