So it's been a couple of weeks since installing my setup. It's rubbing a little bit, figured I'd post a little bit of an overview:
Car: 2014 FiST
Suspension: Bilstein B14 coilovers set to near max height. Running 1 camber bolt up front with -1.5* camber and slight toe out
Wheel/tire setup: 16x8 Konig Dekagram w/ 225/45/16 Dunlop Direzza ZIII
Impressions: Great setup. Soaks up the bumps a bit better than my 17" setup. Also the extra inch on the tires helps a bit with traction. The downside is that on shitty ohio roads, I am getting some rubbing pretty bad. Mostly on the plastic wheel liner but today one of my tires hit the metal fender tab and it took out a chunk of rubber (see photo). As much as I'd love to run these on the street, I think I am going to throw the Sparcos w/ the 215/40/17 ZIIIs back on and keep the 16x8s for track/autocross duty. I may try to play with the coilover settings and maybe even install another camber bolt and see if I can get -2* or more camber to see if that helps. But for now this setup is going to chill in the garage until Autocross day
Photos:
Side Profile Shot
Rear Profile
Side by side comparison with my 215/40/17 ZIII
Results of rubbing - Chunk of rubber torn from tire
Car: 2014 FiST
Photos:
Side Profile Shot
Rear Profile
