Okay, here's another thing that would be nice to have in the manual:
Instructions for use of the Ford Trigger TPMS activation tool. Since the vehicle comes with summer-only tires, obviously many FiST owners will be swapping between winter and summer rigs, and will be faced with the TPMS issue in one way or another. So, here's the 411 on that. [Note: These instructions are specific for Ford/Lincoln/Mercury vehicles with push-button starting.]
Ford Trigger TPMS activation tool:
1.
Make sure all tires are inflated to the vehicle specifications.
2. Make sure ignition button is OFF, then press and release the brake pedal.
3. Hold the ignition button down for 2 seconds, release it, and then tap the ignition button once. The vehicle should be OFF. Hold the ignition button down for another two seconds, release it, and then tap the button once.
4. Hold the ignition button down for two seconds again. The vehicle should be in RUN mode, engine off.
5. Press and release the brake pedal.
6. Tap the ignition button once, so the vehicle is OFF.
7. Hold the ignition button down for 2 seconds, release it, and then tap the button once. The vehicle should be OFF. Hold the ignition button down for another two seconds, release it, and then tap the button once.
8. Hold the ignition button down for two seconds again. The vehicle should be in RUN mode, engine off.
9.
The horn should sound letting you know the vehicle has entered into TPMS relearn mode.
10. Place the top of the FORDTRIGGER tool on the sidewall of the driver's side front tire in the location of the valve stem.
11. Press the button of the FORDTRIGGER tool.
The vehicle's horn will sound letting you know the sensor has been learned.
12. Once the horn sounds, move on to the passenger side front tire and repeat the process. Each tire should only take 30 seconds or less.
13. After the passenger side front tire has been learned, continue on to the passenger side rear tire and finishing with the driver's side rear tire. You will move in a clockwise direction around the vehicle as you activate the TPMS sensors.
14. You may now turn the ignition to OFF.
If the horn does not sound, the sensors were learned successfully. Congratulations! If the horn sounds twice, then the process must be repeated, because there was a malfunction.
