Can I please hear feed back about this. I’m looking into exhausts and this seems to be the one I’m favored towards.
The drone with the MBRP is ear-piercing, and definitely falls within the range that it'll cause long-term hearing loss. It's not the primary noise, the sound you hear from the exhaust outside - it's the secondary drone that resonates inside the body of the car. I was able to resolve it but it adds a few hundred bucks to the exhaust. If you are looking to avoid the drone, just get a thermal. Anyone whom says the MBRP does not drone believes so because they've probably already lost hearing in the 107hz range. It's clearly visible upon spectrum analysis. The MBRP is also not very well engineered, as the bends where it comes from the downpipe then up over the mid-chassis brace, and the little "arms" that go into the exhaust hangers, are not consistent from one exhaust to the next. That's why some people have fitment issues and others don't. I know what I am doing with exhaust system fabrication and installation, and even I have been unable to get my MBRP to fit without touching the mid-chassis brace. It results in a banging sound over bumps and occasional buzzing, even with washers added to the brace for clearance.
Thermal is the most drone-free exhaust made for the Fiesta ST, since it incorporates a properly sized quarter wave resonator into it's muffler.
The CP-E is the second most drone-resistant exhaust made for the Fiesta ST, though it's helmholtz chamber is less effective in attenuating the 106-107hz range.
There are several others that have less drone, but unless they're actively cancelling that 106hz resonance, they're going to drone (if they're 3").
If you go MBRP, don't drive the car with kids in it, you'll be causing them permanent hearing damage while their ears are still developing.
As to why I own the MBRP - I cut my hand on my custom exhaust and needed something *now* - whoosh had them in-stock, so I ordered one figuring I would also prove it was possible to make an MBRP drone-free. If Ron had had the Thermal in stock, I would have ordered one. It is possible to kill the MBRP drone, but it's complicated to do and requires modifying a brand-new exhaust.
https://www.fiestastforum.com/threads/im-at-it-again-fixing-drone-on-a-brand-new-mbrp.20873/
