Planning to flush the brake fluid and knowing the clutch system uses a secondary reservoir that pulls from the brake master cylinder reservoir, I was hoping someone could provide insight on how to flush the clutch fluid.
I know there's a bleed nipple near the transmission?
I basically need clarification on the procedure to flush it. For example, do I top the master reservoir and then open the clutch bleed?
Or do I top up the secondary reservoir and then open the clutch bleed?
Also should i flush clutch first then brakes? or brakes then clutch?
