green_henry
Pleasant Hill, CA
I picked up some MT-LV from Red Line Oil in Benicia today; supposedly it's a better match than their DCTF (go figure!). I couldn't find MT-LV locally and even Summit doesn't list it (yet), so luckily it's a short drive to the source :cool: I haven't had any issues with their DCTF, but I feel a little more comfortable using a fluid that conforms to the factory spec (Ford WSS-M2C200-D2). I will follow-up when I get around to making the swap -- hopefully this weekend [wrenchin]
Spork1569
Fillmore, CA
Added some interior bling to the car. Love the look of the black hole cover but getting it in a usable spot is pretty hard.
Also ordered the missing parts for my intake upgrade(St200 airbox, inlet elbow) and the crossover pipe and induction hose should be on the way soon. Excited to be able to install it all.
Lisle
Yeah I know, looks like an excessive Wang but it makes for a more aggressive look from the back, and guess what? my rear is staying cleaner longer....and these are Hypergrams with 215's
Yorktown
Got my all weather floor mats in from a user on the forum and much better than carpet[emoji108]
shouldbeasy
Calgary, AB, Canada
While everything was apart I went ahead and ported my exhaust manifold - there were distinct carbon rings on it where the gases from the block were coming and hitting it - opening it all up should improve air flow.
And the Pumaspeed turbo elbow also had some lips on the inside which I knocked off best I could:
brbauer2
St. Charles
Buddy bought mud flaps from a guy online.
Buddy didn't check carefully enough what car they were for - he drives a FoST.
Buddy sold them to me super cheap [emoji41]
I put them on today!
Pro tip - grind the middle screw for the fronts down to avoid it rattling against metal.
Sent from my OnePlus 6T using Tapatalk
Yorktown
That plate color is dope af bro [emoji108]
Lisle
Suspension Install today...
Went with Bilstein B8's in front and Koni Orange in Rear with H&R Sport springs I got from Whoosh. Also while I was in there I did rear pads and rotors. Replaced all related bolts as well as all the mounts and suspension bits and pieces (spring mounts, bumpers, dust covers) I ordered from Tasca and put camber bolts in front for a little negative camber to minimize rubbing. Made sure everything was straight and put everything exactly back where it was so I dont need an alignment at all, straight as an arrow. Get a little rub on big bumps running 215's but man is the ride completely different in a great way.
Mikey456
Los Angeles
Why did u get different brand shocks in the rear than the front?
Lisle
Because its damn near impossible to get a right front Koni orange strut (backordered for a unknown amount of time) and it's also damn near impossible to get a rear set of Bilstein B8's so I mixed it up a bit and tried something different...also was originally going to go with Whiteline springs but those were also backordered so I got these H&R's...so far no complaints...the combination here gave me perfect results in my opinion, nice ride and pretty low, if I didnt get the camber bolts I would've had some problems.
Washed the little whiny blue car and got my new carbon fiber keychain cause I lost my whoosh ST dongle one some where over the rainbow....:-(
Had to wash the old Battle axe also! Also Jet sealed it ....had it laying around. Thought I'd give it a whirl.....it turned out pretty darn good....now comes the longevity test....the Fist will get it tomorrow!
