@jeffreylyon....You know I don't like you trolling my post, BUT to answer your question.... as I stated in my OP the voltage was tested and I have been running this now for 3 weeks with no issues to alt voltage or Battery drop. So with this pulley it is only 3/4 of a inch larger than the stock clutched pulley....Without getting into any long drawn out discussions. To simply answer your question NO...It does not affect voltage. A FORD master mechanic is actually the one who put me on to this specific pulley size, its a standard FORD pulley that had the snout machined to fit flush on the Alternator. This is not some homemade grinder machining, this was machined on a lathe the size of a car that's used to machine aircraft parts man. The pulley is well thought out and machined to work perfectly. That's why I personally tested all 6 on my own vehicle a week before even making this post. I have two going out for 2 people to test, The results will be in soon for everyone to make there own judgement on if they would like to purchase or not.
Wow, are you delicate. I posed a question to a brand new member and vendor to this forum; I did not troll. But, since you answered my question with a bunch of anecdote rather than just putting a voltmeter of the battery terminals at idle, OF COURSE YOUR PULLEY AFFECTS ALTERNATOR VOLTAGE. If you spin an alternator slower, it produces less voltage. That's why there's a voltage regulator and why the alternator and pulley are sized to ensure that the alternator is producing enough voltage and is able to supply enough current at idle with the high beams and fog lights on, A/C running a full tilt with fan set to max, and a thirsty battery. That the pulley is a FORD part, that it's turned on a high quality lathe instead of ground on in your house, etc. makes no different to the alternator, which is now spinning more slowly.
Let's do some assumptive math. On a perfect day I'm motoring around in my FiST. A/C off, lights off, etc. So the electrical drain is the LPFP, the injectors, the computers, the instruments and the electrical power steering when I turn. I don't know how much power steering drains, so I'm going straight for this exercise. I'm going to assume that's, say, 10 amps of draw and then double it - 20 amps.
14VDC @ 20 Amps = .28 KW = .36 HP
All the electronics on my car are drawing .36 HP direct and some due to inefficiency of the alternator. Make it easy, say the alternator is only 33% efficient. Rounding off, that's 1 HP. So if I took my alternator off and ran my FiST 0-charge, like my race car, I'd gain 1 HP. The only reason I run 0-change of my race car is weight because the drain of an alternator is zip, esp. when I'm not running lights or A/C.
The interesting thing is that an alternator does not induce drain as does, say, a water pump. A water pump is always pumping. An alternator supplies current as needed - more electrical load == more current == more drain. That's why older cars drop revs. at idle when you turn on the lights - more load.
What works for you on your commute might completely fail for someone stuck in stop and go traffic with the A/C and lights on.
For sure there's less of a dynamic load b/c you're spinning the alternator up more slowly. A V-dyno would show that improvement. Why not post a before and after?
You see where this is going. I love the entrepreneurial spirit - back it up with some facts and a lot less whining. You want to sell on this forum? Give one to Jeff and let him do a review. He's fair, comprehensive, and trusted and that's worth a lot more than $35 of direct cost. In the meantime, build some facts about your product - not that it's turned on a nice lathe, but the positive effect on the cars of the people you're trying to turn into customers. If you can prove a 2 HP improvement with no loss of function, then you've got a winner. If not, everyone on this forum deserves to know that before you take money from them.
