- Member ID
- #9572
- Messages
- 24
- Likes
- 5
Also if you're lugging the engine in higher gears at low rpm it's going to use more fuel than being at higher rpm with light throttle.
RPM kills mileage more than anything else. At 4k your injectors fire twice as often as at 2k. Pulse width of course makes a difference, but half throttle at 4k can use more than full throttle at 2k, which is why it tells you to shift up when you're using "light throttle at high rpm"
The program isn't wrong or broken, it's trying to get you the best MPG...
As for me - about 26.5 is the best I've ever seen. Lots of heavy traffic, punch it when i get a chance, 60 mile commute every day.
