True, Koozy, but I'm not going to do that without a sponsor.
I switched from OEM to Motul Multi DCTF at 2,539mi and from Motul to Ravenol at 7,950mi with my LSD installation. A lot of variables there, but I don't have the time, money, or patience to attempt anything close to lab-like testing on my daily. The improvement was pronounced enough that I'm confident that Ravenol is a superior fluid for this application.
Is the car still in "open loop" or has it changed over to "closed loop" when you experience this? That is to say, has the idle RPM dropped before you shift? That may be your issue. No matter what, I
always wait for a car to switch to closed loop operation before I put it in gear so that it is operating under the best fueling conditions that it can when under load. You may also just be hyper-sensitive to dry/cold shifts.
Here is a decent enough explanation of closed vs open loop:
https://www.hotrodhandbooks.com.au/eBooks/TPI/TPI On Line-03-2.html
