I wanted to start a discussion on unsprung weight and it’s potential effect on brake temps. Long story short, I’m interested in what i term quality of drive modifications to my car, things that will help magnify the traits of the car that I like, without hurting the things about the car that I do like.
Two things that I’ve set to eliminate or mitigate are heat soak of the engine, and heat soak on the braking system. Since this is in the brakes forum, I’ll focus mostly on that here.
My main question is, if I were to remove 6lbs of rotating mass per corner, would I see a reduction in braking temps? Ideally on the front axle since our torque vectoring system really heats the front pads up when the road gets twisty.
I know an LSD is the correct answer for this specific question, and I know whoosh even sells some underbody fins that act as kick ups to help cool the brakes, but I was just wondering if anyone on the forum has seen an improvement on fade resistance after they’ve installed a lighter wheel/tire setup on their FiST.
