I’ve read that high boost levels and OEM coil packs can cause the breaking up or sputtering that I am experiencing. And I don’t want to spend the money on OEM coil packs if I can get aftermarket
I’m in the process of getting a custom tune by Jason at DizzyTuning. But I can’t send him WOT logs due to this issue I’m having. And I’m catless. Ngk 11 iridium one step colder plugs. I bought two different sets of plugs to see if it was that but it wasnt
No it wasn’t. But it ran fine for about a week or two. The issue started happening after I had to leave somewhere in a hurry and didn’t let the car warm up. Following that day it was doing this ever since
If It was me....I'd go back to catted as the no cat on a stock Turbo gains are negligible....plus you save the barking spiders in the sequoia national forest in Yosemite. Did you use any o2 trickery/ elbow for the the Down stream o2? Did you go the plugs also? Where did you buy them from? Did you use Di-electic grease on the plugs in the boots at all?
I have the o2 bung elbow but I never put it in. And I don’t believe the cat would make the my car break up in low rpms on full throttle. Plus I got rid of the cat
Did you inspect the plugs before you put them in for possible shipping damage? Cracks in the porcelain? I think you might have a bad fuel pressure sensor possibly also. What's the mileage of the car?
