If you've got a 2867R then, yes, there is a very good reason to wire up the 4 port. I think that what you've been told is that you can run E85 and make good power but you'll need to upgrade the LPFP to push enough fuel to the HPFP and 4 port. Whether you can make much more on E85 over E50/40/30 is something your tuner can answer. I don't think that you'd need to upgrade your LPFP to max out on E30.
