Hi everyone! I just wanted to share with you all a project I've been working on recently. I own a 2016 Fiesta ST USDM spec and for an intake I am running the euro ST200 intake. As most of you know that intake include a fresh air induction hose that you can route wherever to gain fresh air. After running the hose just tucked up under the driver side headlight I figured there had to be a more elegant solution to the problem. My answer to the problem was to design and 3D print a replacement for the factory fog light. This is a direct replacement for the fog light using the same mounting points and requiring no modification to the body of the car and accepts the induction hose. The design utilizes a 70mm LED ring and plugs in to the factory fog light harness. The passenger side is just a blank that accepts the LED ring so there is symmetry between the two side. Overall I am happy with the results and was a fun project for the weekends.
Software used:
Fusion 360
Simplify3D
Printer used:
FlashForge creator pro
1.75mm ABS filament
LED rings:
70mm diameter
5800k
Purchased from superbrightleds.com
Software used:
Fusion 360
Simplify3D
Printer used:
1.75mm ABS filament
LED rings:
70mm diameter
5800k
