Like the title says I am asking if anyone has found any regular strut fit (NOT a coil over setup) 3/4" to 1" lowering springs which are LINEAR rate, NOT progressive rate, which have a higher spring rate than even the Swifts?
I can accept a spring like the Swifts with their 'tender spring' coils on the top, but do not want an actual progressive rate spring (they would be going over/with Koni Sport dampers).
Thanks in advance.
IF these just do not exist anywhere, I am going for the inverted M-Sport R1 Bilstein coil over setup with their tarmac spec springs on them, and Team O'Neil's upgraded, rally spec top mounts.
Thanks in advance.
