I remember in manual transmission class we had a Ford ranger transmission that was rated for automatic transmission fluid. Someone had put gear oil in it and it actually destroyed the transmission. There was a little plastic pathway for the oil to flow to a certain spot, and I assume the gear oil was to heavy to flow where it was necessary.
Throw out the various specs referencing the amount and fill 20mm below the fill hole is the safest bet. Several members have gone so far as the measure the amount and their findings are alarming in that, in many cases is way under 20mm.
