Shipped today:
[MENTION=10300]ilivefaster[/MENTION] [MENTION=5286]Sticky[/MENTION] [MENTION=10713]PartyCar[/MENTION]
Packing up the rest tomorrow and delivering to post office when they open on Monday.
A note to those folks with a new model year FiST.. The current key fob is different than the previous generations. The little indents on the side of it are no longer there. The key fob holder uses those indents to hold onto the fob.
Oh wow I had no idea. Thanks for the heads up! I had mentioned in the description that it uses the two dimples but I've modified the description to warn people to check if their keyfob has the two dimples.
Do you have the newer keyfob or the older one?
If you have the new fob generation that doesn't fit, then send me some pictures of your fob. If the design is the same other than missing those dimples, I should be able to modify the design to make it work with your keyfob and I'll send a new one to you.
Got mine in the mail too, I plan on installing the extender tomorrow. I might use stronger double stick tape, I got a roll of the industrial grade stuff.
Nice touch on the hidden .com sig. on it
I will post a pic as well when I get ur done
Thanks! Lookin forward to the pics.
Upgrading to a stronger tape is a good idea but I suggest you try to avoid using tape that is very thick, as it may prevent the extender from seating in all the way. However, the change should be minimal and you probably won't notice any difference either way so it shouldn't really matter. Just a suggestion.
