Just received my set of ducts today. Excellent build quality and quick shipping. I can't wait to get them on next summer.
These are a must have if you are tracking on 15" wheels, IMO.
I ran TD PR 1.2s in 15x8 with RE71Rs on track and autocross last summer. After my first track day, I had to use thermal reflective tape on my front wheel weights because they would get so hot that the adhesive would melt and I would lose my weights in the paddock. Later last summer after track season was over, I had to replace the left front wheel bearing. Only the left front bearing was making noise but I went ahead and replaced both front bearings as a preventative maintenance measure. The front bearings are dual row ball bearing and the outer row on the left side was purple due to heat. I was running Mountune RST front pads, Stoptech slotted rotors , Motul 600, and Stoptech stainless brake lines.
Definitely need a brake cooling solution so I think these will fit the bill.
Thanks again to CMBuildz for doing another batch of these!
